What is this for
1941 farmall a
03-28-2007 13:16:47
third party image
Hi all This is on my tractor and I have no clue what it is lol. So do any of you know what it is? Thanks for the help
switchmaker
03-29-2007 14:40:53
 Re: What is this for in reply to 1941 farmall a boy, 03-28-2007 13:16:47
My view it does look like diaphram operated. Which would make the exhaust theory right. But I have never seen,I have heard of, that assist.
Very Intersting!
Will Sick
03-28-2007 19:56:02
That is the mechanism that released the lever on the exhaust or pneumatic lift control lever on the A and B Farmall. When the implement reached the up position the pressure went into this and that prong which held the control lever back lifted and released the lever back to the neutral position. I started cultivating with a B in 1941 when I was 9 years old.
1941 farmall a boy
03-28-2007 21:32:39
 Re: What is this for in reply to Will Sick, 03-28-2007 19:56:02
COOL I had no clue what it did lol thanks a bunch
El Toro
03-28-2007 14:40:34
Village Power Equipment is suppose to have parts for the exhaust lift. Give them a call at 978-838-2484. Hal
georgeky
03-28-2007 14:24:42
I suspect Brad is right about the lift. I have never had one with the erxhaust lift on it. Like I said I was guessing to start with.
Brad in TX
03-28-2007 14:19:20
I'm pretty sure it is a piece that works with the exhaust lift adjustment lever for early A's. If you want to get rid of it send me an email, I've been looking for one. The hole is where the early style magneto kill switch was mounted.
1941 farmall a boy
03-28-2007 14:34:08
 Re: What is this for in reply to Brad in TX, 03-28-2007 14:19:20
How dose it work? When Igot the A all the hoses was gone off the the lift. So I have no clue how it all gets put back.
Brad in TX
03-28-2007 14:43:01
 Re: What is this for in reply to 1941 farmall a boy, 03-28-2007 14:34:08
Send me an email and I'll scan the operators manual for you that shows how its connected. I've got a 1940 and a 1947 A both with exhaust lifts but they both have the later style adjustment levers on them.
1941 farmall a boy
03-28-2007 13:54:49
 Re: What is this for New pic in reply to 1941 farmall a boy, 03-28-2007 13:16:47
third party image
One more photo
georgeky
03-28-2007 14:05:17
 Re: What is this for New pic in reply to 1941 farmall a boy, 03-28-2007 13:54:49
were is it mounted?
1941 farmall a boy
03-28-2007 14:10:40
 Re: What is this for New pic in reply to georgeky, 03-28-2007 14:05:17
Its on the thing that holds the steering wheel I cant think of what it is calld all I can think of is the curvd thing that has the sterring wheel on it lol
georgeky
03-28-2007 13:54:36
Check row planter uses stakes and a spool of wire with knots on it to plant corn in a pattern that allows cultivation from any direction. no matter where you look across the field rows will line up. You didn't get many plants per acre this way. I am not sure that is what you have as I am not to familur with these. I have a check row planter for a C but don't have all the pieces.
Randy in NE
03-28-2007 14:24:38
 Re: What is this for in reply to georgeky, 03-28-2007 13:54:36
I have a check row planter for my Super C. The trip mechanism for the planter is right down on the planter. The wire runs under the left axle. I have never seen the item in the picture but it doesn't look any thing like my planter. I would go out on a limb and suggest the exhaust lift.
georgeky
03-28-2007 15:11:55
 Re: What is this for in reply to Randy in NE, 03-28-2007 14:24:38
Yes I think it is for the lift now after Brad mentioned it as I said it was a guess. It didn't look like anything on my planter either but I don't know what may have been on an A or B. I dont have all the parts to my planter. It is really a HM planter with an adapter to make it work on a C. I am missing the spool and all related parts to it. The reason I thought it may have been a planter part is that the spool and some of the parts for a front mount C planter mount on the tractor and I don't know what they look like.
georgeky
03-28-2007 15:07:30
georgeky
03-28-2007 13:27:01
Not sure. Maybe for check row planter.
1941 farmall a boy
03-28-2007 13:42:37
 Re: What is this for in reply to georgeky, 03-28-2007 13:27:01
Whats that lol. I do have the lift all on it. I can get some more pics on hear if you need them.
