Not bad for a country
Bid Country
03-28-2007 15:53:45
third party image
I have been working on this 400 since the middle of Dec. It all started with a TA repair. So why not go ahead and paint. It has been a job, but I think it look so far. I hope the picture gets on here. I use IH 2150 paint. Here are some picture if you want look at them>Link
>Link
Kelly C
03-29-2007 06:03:32
 Re: Not bad for a country in reply to Bid Country, 03-28-2007 15:53:45
Wow!! that really looks nice. Good job.
400 is my favorite tractor.
JFAVOR
03-28-2007 19:32:37
Just painted my 51 H with ppg acrylic enamel. This is not cheap. 2qts of paint, 1 gal reducer, 2 cans of hardner cost $225.00. Plus primer, sealer, sand paper and buffing pads and compond. I'm getting close to $400. But, the paint looks great. I had planned on using the tractor but now, not sure I want to. Many hours of prep work.
Randy SE-MN.
03-29-2007 03:36:12
 Re: Not bad for a country in reply to JFAVOR, 03-28-2007 19:32:37
Don't you mean 2 GALLONS of Paint???
Mike CA
03-28-2007 19:03:25
Looks great Biggy! Can't wait for more progress pics. Do you plan on spraying a clear coat?
As far as prep, I'm learning that a great paint job is 90% proper, well done prep work, 10% thin paint spray. Looks like you are doing well along those lines!
Big Country
03-28-2007 18:36:15
 Re: Not bad for a country boy in reply to Bid Country, 03-28-2007 15:53:45
third party image
I used Factory paint from the dealer, I used a wet look harder for acrylic enamel. It is from mar-hyde, No 2612. and a good acrylic reducer. I also use John Deere yellow buff primer. It took a long time to get the prep job done. This tractor was so clean you could have eat off it. Now that I have learned to post pictures, I will keep you guys informed.
JayWalt
03-28-2007 16:42:00
Looks GOOD!!
That is definitely RED!! Needs some odds and ends to break up the massive amount of red. I'd like to paint mine, but I dont have the patience for proper prearation. It would be a total PITA, heh.
Keep us posted and of course pot some pics when your done!
SDE
03-28-2007 16:33:17
I sure hope I can do that good of a job someday on my 400s. How much paint will it take to do thee entire tractor?
Don LC
03-28-2007 18:27:32
 Re: Not bad for a country in reply to SDE, 03-28-2007 16:33:17
Been awhile since I painted one, seems like 1 gal. paint and about 3 qts thinner. Most guys make the mistake and put way more than nessary..... .the tractor looks like candy,paint thick.....
georgeky
03-28-2007 16:31:19
I wish I had a couple coming along that good.
skycarp
03-28-2007 16:11:50
Looks real nice, better than factory I bet. Who made your paint, what type, and are you using a hardener in it?
Big Country
03-28-2007 15:58:02
Sorry for type mistake, it should read Big Country.
