Farmall A Build Date
John in Piedmon
03-28-2007 17:58:30
I have a newly purchased Farmall Super A with a serial # of 271410 and was curious if anyone has info. on a build date for this tractor. Thanks.
Jim Becker
03-28-2007 21:36:05
 Re: Farmall A Build Date in reply to John in Piedmont, VA, 03-28-2007 17:58:30
Feb '49.
Will Sick
03-28-2007 19:43:31
If you look under serial numbers on this site you will find that it is a 1949.
HAS
03-28-2007 18:37:57
I don't think that is a valid Farmall A serial Number. Where did the number come from? It should be on the left inside of the seat bracket, and also can be found on the engine, a raised portion of the block just above the magneto or distributor whatever you have.
James Williams
03-28-2007 18:01:21
John,Where are you located in VA
