Farmall Hydro 70
Dave in Upstate
03-28-2007 18:57:07
i have a hydro 70 great tractor BUT it put a rod out the side of the block 312 engines are hard to find and EXPENSIVE! i found a 310 out of a 715 combine and adapter plate to bolt 310 into the hydro70 my question is will flywheel from 312 out of the hydro 70 bolt onto 310?
K.B.-826
03-28-2007 21:16:04
 Re: Farmall Hydro 70 in reply to Dave in Upstate NY, 03-28-2007 18:57:07
Looks like you're going to need a flywheel from a 310-powered Hydro 86. Parts book also shows that the crankshaft used in the 715's 310 is different from the crankshaft used in every other application. I can't remember what exactly is different about it, think it has something to do with the pilot bearing, or possibly the flywheel mounting flange. All I know is that I've heard of guys running into flywheel snags trying to put 715 310's into 706's, ect. Have you looked for a D-360? Those were basically the same as a 312, and should be more common and easier to install than the 310.
