Hey Jay, Ready to start boiling
Gary in Mozarks
03-28-2007 21:20:41
Jay Walt, Well, tomorrow morning I'm ready to start boiling hydralic fluid. I got my 5 gal aluminum pot, my propane burner and candy theomoter. I will try to take some pictures. I have a cloth filter over a big metal funnel to filter it as it goes back in. Ya know, Reading all these posts about milky hydralic oil, we should come up with some way to make it into something we can burn like bio diesel. If they can run a truck on frier grease, then it would seem like there should be some way to recycle hydralic oil as fuel too. Sure is a lot of it out here Gary
JayWalt
03-29-2007 06:07:24
 Re: Hey Jay, Ready to start boiling in reply to Gary in Mozarks , 03-28-2007 21:20:41
yes be carefulwith the flame. Bob, ive let hydraulic fluid set for over a week and it didnt deparate, stil cloudy as can be. I gave up and started boiling =]
I'm sure it would separate after a while.
I actually let my first draining separate because it had some distinctive white stuff in it that would settl out in about 10 minutes, never did figure out what it was, someone told me "soap" heh
JayWalt
03-29-2007 06:07:25
JayWalt
03-28-2007 22:27:28
well i dont know about hydraulic fluid as a fuel, but yes alot of it probabl gets wasted from moisture contAMINATION. Make sure to start it on a semi low flame and stir it rather frequently. The last thing you wanna do is burn 5 gallons of that gold. It will never look like new, but after the water is out, and the oil is filtered, it should be more then good enough to reuse or top off the fluids.
Seems like most the people here thought I was a bit loopy when I posted my apparatus for separating, boiling and filtering my fluid. I still ended up buying 5 gallons of it, but still saved some money and i got about 4 gallons left for topping it off and whatnot. If yo can get some pics, it'd be nice to check it out.
You'll know its finish because it will actually form bubbles at the surface like when u put some water in a deep fryer, not nearly as violent because of the lower temp, but when you dont see anymore bubbles forming, you know its done.
Whats really weird is if you spill the fluid on your tractor like i did, come out a week later in the garage and open the door and let humid are in and it hits the cold tractor and condeses and turns all the fluid white, it looks really weird, hahaha
BTW, after u get all this sorted out, might be best to put a new filter on her too.
Gary in Mozarks
03-28-2007 23:30:52
 Re: Hey Jay, Ready to start boiling in reply to JayWalt, 03-28-2007 22:27:28
The last ten times i cleaned the old filter and put it back. I ran 5 gallons of Kerosene/fuel oil mix in it and flushed that out. Now its ready for refried Hy-Tran. It seems odd that it will burn so easy. When i get done, and i have run it for a while with this oil and I am satisfied I have the system clean, I plan on a new filter and new oil
Bob
03-29-2007 00:03:34
 Re: Hey Jay, Ready to start boiling in reply to Gary in Mozarks , 03-28-2007 23:30:52
This plan reminds me of "Hey! Hold my beer; and watch this"!
Assuming nice warm weather; I wonder how it would work to allow some time for the water to settle to the bottom and drain it off; then allow the oil to flow slowly by gravity through a "Luber-Finer" diesel engine "bypass-type" oil filter. They are filled with cotton waste; and SHOULD take MOST of the remaining moisture out of the oil.
NOT as much "fun" as the "turkey fryer method" though!
All I can say is "Be careful" and "Good Luck"!
georgeky
03-29-2007 08:27:16
 Re: Hey Jay, Ready to start boiling in reply to Bob, 03-29-2007 00:03:34
Bob, my grandpa use to do that with oil, I am not sure how, but he called it wicking the oil. Seems like it took him several days to do this.
Gary in Mozarks
03-29-2007 11:28:30
 Re: Hey Jay, Ready to start boiling in reply to georgeky, 03-29-2007 08:27:16
George, I don't know if you saw the post I wrote last week but I recall my dad wicking oil to clean it back in the 50's when he was laid off. He would take a pan of dirty oil and place about 20 strips of cotton around the edge and place another bigger pan under it. The oil would wick up the cotton, trap the dirt, and then drip clean into the lower pan.
Bob
03-29-2007 11:48:26
 Re: Hey Jay, Ready to start boiling in reply to Gary in Mozarks , 03-29-2007 11:28:30
I understand a length of rope can be used to "wick" oil like that; from one container down to another; leaving dirt and grit behind.
I want to try that to clean up used oil for use in a used oil burner.
I suspect it's best to do that in HOT weather and to allow LOTS of time though!
Gary in Mozarks
03-29-2007 00:18:56
Yep, its the missouri way... Hey Hun, watch this!! Don't have any of those so-fist-icated things but I got a turkey fryer LOL Don't try this at home. seriously, Gonna do it ouside on gravel so it shouldn't be to big a fire.
