FARMALL B TRAILERING
LONESTAR
03-29-2007 12:24:23
I WAS GIVEN A LITTLE B FARMALL AND WAS WONDERING WHAT I WOULD NEED TO DO TO GET IT ON A TRAILER I HAVE AEXTRA WIDE 16FT FLATBED AND WAS WONDERING IF I COULD GET IT WITH NO PROBLEMS OR IF I NEED SOMTHING DIFFERENT.
L Mack
03-29-2007 18:32:03
 Re: FARMALL B TRAILERING in reply to LONESTAR, 03-29-2007 12:24:23
I have to completely close in the rear wheels to the most narrow setting to use my trailer for my B or a super c do have a two by ten to load the narrow front larry
JT
03-29-2007 15:27:12
you will need almost all of an 84" wide trailer, I put mine on my 84" and it just about rubs both sides of the rails.
Red Dave
03-29-2007 12:38:45
I haul my B on a 7 foot wide trailer. If the trailer has sides and you have the wheel weights on the tractor, it needs every bit of 7 feet.
glennster
03-29-2007 12:35:45
if your trailer is extra wide you should have no problem. i have a standard beavertail carhauler, the rear tires hang over the sides a bit but not a real problem. take some 2x8's to make a center ramp to get the tricycle front up on the trailer. i'd take a floor jack, come along and some sockets in case you have to narrow up the rear wheels.
