M high dome pistons
Lee @ Elk Mound
03-29-2007 12:56:35
Do the high dome pistons in my converted LP M increase HP very much, or any? Do such pistons make an otherwise ordinary M engine any more valuable?
Thanks.
Lee @ Elk Mound
Lee @ Elk Mound
03-29-2007 16:22:26
 Re: M high dome pistons in reply to Lee @ Elk Mound, 03-29-2007 12:56:35
Thanks. I'd heard that some of these "pull" guys can get as much as 100+ hp out of these M's doing various shavings and having high domes.
Lee @ Elk Mound
Janicholson
03-29-2007 13:24:44
Yes. The compression ratio could be high enough to use premium fuel (If converted to gasoline). The power is very noticable. The increased compression takes advantage of the "Equivalent" high octane of LP gas, Off setting to a degree its lower energy content per liquid unit. JimN
