Farmall 300 Hydralics
Hogman
03-29-2007 18:18:25
I have three levers on the right side of the tractor..... .The far right lever lifts the 2 point hitch..... ....It quit working.....The lever can be pulled out..... ....What holds the rod and lever in????? ???Thanks Scot
georgeky
03-29-2007 19:26:36
 Re: Farmall 300 Hydralics in reply to Hogman, 03-29-2007 18:18:25
Hogman on the end of that shaft is a lever that hooks to the lever that operates the valve it is attached with pin that goes through the shaft and lever it has likely wore into. You will have to remove dash to fix it. Pull lever all the way out and you will see the hole I am talking about. It is a easy fix once you get that dash off.
