injector hose number,2500A
maplehillfrm,pat
03-29-2007 21:55:13
I noticed a fuel leak today under the hood, it appears the braided hose rail on top of engine is leaking.
does any one have the part number and where I can get teh braided hose that goes from injector t o injector on this engine, I think it is a D206. I cant find my parts book at this time.thanks pat
Fromjb2
03-30-2007 10:39:06
 Re: injector hose number,2500A in reply to maplehillfrm,pat, 03-29-2007 21:55:13
Hi Pat, According to CNH parts book the engine is D239 same as ag 574, now here is the catch it may have a CAV or Bosch injection pump and the part numbers are different depending on the type of injection pump. CAV usually has a metal ID tag attached to the injection pump and requires a lift pump on side of the engine. CAV p/n 3055606R91, Line, Pipe Leak
Bosch p/n 3055606R1, Tube Leak
You can visit the CNH parts web site at:
Link
Then select: Begin your SEARCH for PARTS right here!
Then in the new web page that comes up in the Model search field put 2500 and click search button.
JimB
