IH766
Lance Adams
03-30-2007 15:04:55
I bought a 766 IH tractor, with what I was told had a blown T/A. The question I have is if the T/A is blown, then the tractor shouldn't move at all right? I have been able to drive it with T/A lever all the way back. I am also wondering if I just have a Range transmission shift linkage problem? The trans was 8 gallons low when I got it, and when I filled it I was able to drive it; but shifting is a problem. Thanks for anyones help! Lance
the tractor vet
03-30-2007 17:36:32
 Re: IH766 in reply to Lance Adams, 03-30-2007 15:04:55
what you have here is a problem with the clutch adjustment along with the othewr stuff that is all hooked into the clutch linkage . Now what i need to know from you is does this 766 have a Hyd. assit. clutch or if it is just and old run of the mill manual linkage . Then i can explain what ya need to do to make this all better .
steve from mo - dangit!
03-30-2007 16:37:34
 Get the manual. in reply to Lance Adams, 03-30-2007 15:04:55
You may have got really lucky, but get the manual and/or find someone who has done this a few times before. Allan out in Nebraska comes to mind.
