Farmall a
PA farmaer
03-30-2007 21:17:06
I am working on painting my A i was taking the wheels off when i notice that the right hub is about 2 inch thich solid cast and the lift side was a thin tin hub. I was just wondering which was the corect hub. thanks DEVIN
Bob
03-30-2007 22:01:22
 Re: Farmall a in reply to PA farmaer, 03-30-2007 21:17:06
BOTH are correct. Since the tractor is offset; the outboard hub is made HEAVY to act as a counterweight to help with the tractor's stability. In other words; to make it less likely to tip over sideways.
