4050 oil pan
Pete1468
03-31-2007 10:10:29
I'm working on a 4050 with a quad range tranny. I normally work on red ones but a friend of mine needed a favor so I'll ask a couple of questions. I want to take the oil pan off to check the rod and main bearing. Does the oil pan also hold back tranny fluid, and just how heavy is that thing. I think I'll try and set it on a floor jack so I don't drop it on my foot.
Bob
03-31-2007 11:44:17
 Re: 4050 oil pan in reply to Pete1468, 03-31-2007 10:10:29
The clutch is "wet"; but there's only a SMALL amount of residual oil that remains in the housing when shut down. NO rear to drain the rear end behind the clutch housing.
dwag
03-31-2007 10:32:13
Yes, Quads have oil in bellhousing, so you need to drain oil. Pan is a handfull for an ave+ man, 2 guys easy.
dwag
04-01-2007 10:51:31
 Re: 4050 oil pan in reply to dwag, 03-31-2007 10:32:13
Sorry for the misinformation. I have always mistakenly drained a few gal of hyd\trans oil before splitting tractor.
