jumping tractors
james braley
03-31-2007 15:11:25
can you jump a six volt with a 12 volt. if so how many times can you do it with out hurting the tractor.
JayWalt
03-31-2007 21:48:46
 Re: jumping tractors in reply to james braley, 03-31-2007 15:11:25
like others have said, if you turn the key on for the tractor to the run position, hook one jumper cable to the ground of the tractor and the other to the input terminal of the starter it will be fine. DO NOT turn the key to start or the solenoid will turn on and backfeed the 12 volts to the battery which is not what u want. Should jump just fine, just dont leave it on too long.
A. Bohemian
03-31-2007 16:44:30
 Move Fast! in reply to james braley, 03-31-2007 15:11:25
Yes, you can jump a 6 volt starter with 12 volts, as long as you hook it up at the starter, as described above (below? when I reply to a post on these boards I never know where it will end up).
It"s done all the time. In most twelve-volt conversions, the original 6 volt starter motor is run off 12 volts as a matter of routine.
But DO NOT crank for more than a few seconds at at a time! In just this past weeek, there have been TWO posts on the 9N/2N/8N board from people who have burned up a 6 volt starter in a 12 volt conversion by cranking for too long!
Yugrotcart
03-31-2007 15:47:27
Never hook 12v directly to a 6v battery, the 6v could explode.
Hook one of the 12v booster cables to ground, the other directly to the post on the starter. All ways best to have a helper seated on the tractor.
Paul
old
03-31-2007 15:45:56
Thats a Yes, NO and sort of. NO you can't/ shouldn't hook a 12 volt battery to a 6 volt battery it could explode. Yes you can make it start with a 12 volt battery but you hook one jumper cable lead to the frame of the tractor and the other one to the starter stud which will then make the starter turn, but if the 6 volt battery is 100% dead it still will not start. So now you see why I say sort of. As I said don't hook a 12 volt battery to a 6 volt battery or you may end up going to the hospital
Yugrotcart
03-31-2007 15:48:49
 Re: jumping tractors in reply to old, 03-31-2007 15:45:56
Guess Old and I were typing at the same time, at least we agree..... ..... ...
Paul
old
03-31-2007 15:57:13
 Re: jumping tractors in reply to Yugrotcart, 03-31-2007 15:48:49
LOL so what do we agree on that its not safe????? ?????
