400 parts help
karl f
04-01-2007 01:43:43
local dealer was no help last year. they said "NLA"
i need the gaskets on the top of the hydraulic reservoir on a 400 farmall. someone at a dealer please contact me. thanks :) new pump is cavitating/growling. gaskets should solve it. or at least stop the oil leaks :)
320. 266 nineteen fifty six.
-karl f
JayWalt
04-01-2007 09:14:16
 Re: 400 parts help in reply to karl f, 04-01-2007 01:43:43
you can easily make a gasket from gasket material, not very difficult. If your pump is growling, check the filter, i dont know where it is on a 400, but it is the most likely cause of the pump growling, either that or air getting into the suction like from a bad oring, or a crack in the pump housing/hoses
karl f
04-01-2007 12:53:08
 Re: 400 parts help in reply to JayWalt, 04-01-2007 09:14:16
pump is new, "filter"(screen) is new. the reservoir cover gaskets and possibly an o ring at that mount point are the last defect in the system. the return and suction lines both are on that top assembly the gaskets seal, along with the valve bodies. definitely a high pressure leak there, so likely a suction leak too.
karl
Jossette
04-01-2007 14:33:19
 Re: 400 parts help in reply to karl f, 04-01-2007 12:53:08
there are 4 bolts on the right side of the reservoir at the bottom--this is the filter and it is probably pluged up tight. I'll try and put a pic up ..
Jossette
04-01-2007 14:37:07
 Re: 400 parts help in reply to Jossette, 04-01-2007 14:33:19
third party image
I believe you need # 18 in pic. send me an email if you need a bigger pic...and numbers
