Super C ground location?
tractorsam
04-01-2007 16:40:25
I need to make up some new battery cables for my Super C and the ground currently runs to one of the bolts that hold the side of the battery box to the back of the 'dash'. It seems that this wouldn't provide a very good ground. Is this the original location and if not where abouts was it? Many thanks, tractorsam
teddy52food
04-02-2007 05:56:34
 Re: Super C ground location? in reply to tractorsam, 04-01-2007 16:40:25
I found it better to run a heavy cable to one of the starter mounting bolts. There is a lot of resistance with the other connections. It might not be original,but with a 6v system they turn & start better.
gene bender
04-01-2007 19:33:50
Thats the original place just clean everything
Brownie450
04-01-2007 17:12:23
Ours grounds to one of the bolts which hold the light bar & steering wheel support. The original ground bolt caused us lots of trouble until we moved it. Doesn't look very professional, but hasn't caused any trouble in 25 years.
CNKS
04-01-2007 17:01:28
Operator's manual shows it attaching to a bolt in the right rear of the battery box, which screws into what I think you are calling the "dash". That part is bolted to the top of the transmission housing. Just make sure all connections are clean.
Andrew Z
04-01-2007 16:58:12
Mine grounds out to one of the studs going into the touch control hydo box. (right in the front of the Bat. Box. )
Andrew
