300 and a 3x16 plow
JR300
04-01-2007 21:19:37
I have a chance to get a 3x16" 2 pt plow for my 300. Will the 300 be able to take the plow or should I look for a 2 x 16"? thanks guys!
dhermesc
04-02-2007 05:11:55
 Re: 300 and a 3x16 plow in reply to JR300, 04-01-2007 21:19:37
You can turn it into a 2X16 by dropping one gang off it. I have a 3X16 I pull with my 350, but I use it very little. Its all it can handle (and then some) in 1st with the TA back when you plow like you mean it.
RAW in IA
04-02-2007 01:24:42
Not sre of the 300, bt we had a 350 and a 3-16 fast hitch plow. Or grond was everything from sand to clay & lime rock, and the only time we had any troble was one spring when it was real dry. Like was said, yo can drop one bottom and se it as 2 bottom .
georgeky
04-01-2007 21:33:03
I should have mentioned that you can take off one plow if you can't pull all three, so if it is price is right why not.
georgeky
04-01-2007 21:27:59
I don't know about your ground,but here the 300 is a little light for 3x16s. Unless you have a lot to plow, I think that the two bottom plow will be the best choice.
