1066 Clutch Hydraulic Assist
Michael Sheik
04-02-2007 05:26:16
Well, just got my clutch all adjusted up and working good 3 weeks ago and when I started up yesterday to use and change oil, I noticed the slave cylinder on the hyd. assist clutch was leaking past the rubber boot. This means I will have to remove and rebuild. I assume I can buy a rebuild kit from IH. I can do the rebuild but when I re-install, is this going to affect the clutch adjustments and cause me to have to have done again. Any tricks?
the tractor vet
04-02-2007 14:49:26
 Re: 1066 Clutch Hydraulic Assist in reply to Michael Sheik, 04-02-2007 05:26:16
Ya , it ain't hard to rebuild one just a couple of O Rings . Now when i do one i run a brake hone down thru it a few times to sorta clean it up and give a new surface for the O/Rings . Use a fine grit stone as ya don't want it to be to rough. and again run back thru the adjusments just to be on the safe side.
