Farmall 703 3 point advice or parts needed
Greg Lasher
04-02-2007 08:46:03
I have a 706 with fast hitch. It is an early round fender tractor. I want to convert it to 3pt. I bought the 3 pt arms but now I need everything else such as the sway contols and the drawbar support. Does anyone know where or who has these items? I guess I could use chains for the sway control instead of the IH set up? Ideas, thoughts ... thanks Greg
Does anyone have a good picture of a 706 3pt so I can figure out all I need and make the needed parts if necessary.
karl f
04-02-2007 19:39:39
 Re: Farmall 703 3 point advice or parts needed in reply to Greg Lasher, 04-02-2007 08:46:03
simplest way is to buy the 2pt to 3pt adaptor tongs, and get a salvage toplink bracket and link.
not 100% correct, but very functional. and you can still use your fasthitch implements.
-karl f
Allan In NE
04-02-2007 08:58:08
Not a 706, but that CAT II hitch is pretty much the same all the way up thru the 966.
Allan
third party image
Greg Lasher
04-03-2007 02:04:05
 Re: Farmall 703 3 point advice or parts needed in reply to Allan In NE, 04-02-2007 08:58:08
THANKS FOR THE PIC -- IT IS JUST WHAT I NEEDED
Greg
