IH 784, How do I add remotes easily, oem?
Mike Warrick
04-02-2007 13:47:50
I have a IH 784 that is in great shape. I only have one set of remotes on it and would like to add another. I was told that I could possibly get another valve body to add to the remote valve. Does anyone have info on this and where they can be found if so? My other alternative is to add on a double or triple spool valve. Thanks... Mike in Waco Texas
Fromjb2
04-02-2007 19:17:25
 Re: IH 784, How do I add remotes easily, oem? in reply to Mike Warrick, 04-02-2007 13:47:50
Hi Mike the additional aux remote kit could be purchased from CNH. Neighbour installed one on his 684 about 10 years ago and it was about $400 CND. You can add spool valves by tapping into the hydraulic return line that goes from the aux valve to the depth control mechanism under the seat. Or purchase a power beyond adapter that goes on outside of aux valve.
Check CNH parts site at:
Link
JimB
