756 pto seal
paul finnegan
04-02-2007 18:17:22
what special tools are required to install a rear pto seal on a 756 farmall. can the seal be installed from the outside and what are the dangers of pulling the seal housing off, it looked spring loaded when i loosened the bolts.
JayIH man
04-05-2007 16:20:21
 Re: 756 pto seal in reply to paul finnegan, 04-02-2007 18:17:22
1000 shaft no problem from outside...540 shaft there is a aftermarket screw in seal from Hy Capacity that threads in on existing threads in PTO where the original tube cover was installed when unit was new. This is the answer up to the 86 series but will not work on 88 series units. Seal sells for about thirty bucks.
PVF
04-10-2007 14:02:52
 Re: 756 pto seal in reply to JayIH man, 04-05-2007 16:20:21
having trouble finding the screw in pto seal for my 756 int. any one know part # it would be a great help .tried hy capacity there not sure without #.
thanks for info and help
pvf.
the tractor vet
04-02-2007 21:25:17
Ya need a special spring compressor or a shop press and a special tool to compress the BIG spring inside and then ya can remove the clutch drum then ya can take it apart , Now the PTO brake is also spring loaded on the rear housing and can safely be removed with a couple longer bolts till the pressure is off then you are at the seal , now having the special tool for seal instulation is nice to have but you can get by with a deep well socket that fits the seal . Make sure that you drive it in correctly and put the oil slinger back in . Get a book and read the section on the PTO . Also when removing the PTO from the tractor it is best done with a cherrypicker and the top 3 pt. plate removed so you can see then as you come out you must tip the rear of the unit down so as not to bang bump the pickup tube as it can be damaged real easy.
IaGary
04-02-2007 19:08:30
The seal is installed from the inside if you want the factory replacement seal.
Not sure on the 756 but they make a seal that you can install from the outside for the larger tractors.
The old one remains and the new is added on the outside.
Gary
Owen Aaland
04-02-2007 22:00:08
 Re: 756 pto seal in reply to IaGary, 04-02-2007 19:08:30
540 RPM shaft seal is installed from the front. 1000 RPM can be replaced from the outside.
Jim J
04-02-2007 19:44:33
If the 756 has the original 540 PTO shaft the shaft id to short for the aftermarket seal.
paul finnegan
04-03-2007 14:05:12
 Re: 756 pto seal in reply to Jim J, 04-02-2007 19:44:33
Thanks for the info, any idea where I might find the exterior seal ,or who makes it.My tractor has the high and the low speed shafts and it is leaking from the low speed.i dont know if the shafts have been changed or not, it has not been worked on in the last 15 yrs.
thanks PVF.
