Loader cylinders bleeding down
Gary in Mozarks
04-03-2007 09:18:54
Can anyone tell me what generally causes hydralic cylinders on the loader, to very slowly bleed down (all four of them) on my 460 utility, or at least where to look first. Thanks
Bob
04-03-2007 09:29:10
 Re: Loader cylinders bleeding down in reply to Gary in Mozarks , 04-03-2007 09:18:54
A worn; leaky "cup" in even one of each pair of cylinders will allow oil to slowly slip from one side of the piston to the other; letting the loader "sag".
Or; the control valves could be worn out.
Gary in Mozarks
04-03-2007 10:46:13
 Re: Loader cylinders bleeding down in reply to Bob, 04-03-2007 09:29:10
Thanks Bob, so it would be safe to say that if I unhooked the hydralic lines from the tractor mounted controler, with the loader in the air and it sagged down, then the problem would probably be in the cylinders? And if it doesn't, the problem is probably in the controler?
Bob
04-03-2007 10:53:37
 Re: Loader cylinders bleeding down in reply to Gary in Mozarks , 04-03-2007 10:46:13
That's a good idea.
I didn't know what to suggest for testing; as I didn't know how your system was "set up"... If the loader cylinders could easily be isolated from the valve.
Janicholson
04-03-2007 10:51:06
Exactly.
Be careful unhooking under pressure. It may be best to support the load, release the couplings, then put the load on the hoses. Some couplers are difficult to remove loaded, and might leak/squirt. JimN
Bobcat
04-03-2007 17:23:52
 Re: Loader cylinders bleeding down in reply to Janicholson, 04-03-2007 10:51:06
If you unhook your hoses with the loader up you will not be able to hook them back up because of the pressure on the hoses!
Bob
04-03-2007 17:26:36
 Re: Loader cylinders bleeding down in reply to Bobcat, 04-03-2007 17:23:52
He will be able to re-connect the couplers AFTER it leaks down!
