axle duals
IHPlowjockey
04-03-2007 10:20:58
I want to mount axle duals on a 1466 with 100" axles and 20.8x38 tires and duals, I bought a set of duals and 9 bolt hubs at auction, my question is how far outboard on the axle can I mount the hub to gain room to mount them?
IH Plowjockey
04-03-2007 17:49:03
 Re: axle duals in reply to IHPlowjockey, 04-03-2007 10:20:58
Can it be just inside the hub about 3"?
Erik in WI
04-03-2007 17:57:36
 Re: axle duals in reply to IH Plowjockey, 04-03-2007 17:49:03
Make certain ALL of your U bolts (on the hub) are attached to the axle. Probably be OK unless you have times where all the weight of the tractor is on the outside dual and the inside wheel/tire is "riding on air" (ditches, etc).
Jossette
04-03-2007 15:51:56
as long as the axle is flush with the outside of the hub you'll be fine..
