544 Farmall
Christine
04-03-2007 15:22:57
Hello. My father needs help/instruction on valve adjustment for a 544 Farmall. Does anyone know where I can go to get info. on this, other than the manual? Thanks!
K.B.-826
04-03-2007 16:14:10
 Re: 544 Farmall in reply to Christine, 04-03-2007 15:22:57
Gas or diesel?
Christine
04-03-2007 17:43:06
 Re: 544 Farmall in reply to K.B.-826, 04-03-2007 16:14:10
Diesel
K.B.-826
04-03-2007 19:50:17
 Re: 544 Farmall in reply to Christine, 04-03-2007 17:43:06
The intakes are set at .010", exhausts are set at .012", cold. Remove the cover on the side of the clutch housing, find the TDC timing mark on the flywheel and line it up with the pointer. There should be lash between both rocker arms and the valve stems on cylinder #1, if not, turn the engine 360 degrees. Adjust both valves on cylinder #1, turn the engine 180 degrees and adjust both valves on cylinder #3, turn the engine another 180 degrees and adjust both valves on cylinder #4, turn the engine another 180 degrees and adjust both valves on cylinder #2.
Christine
04-04-2007 07:39:12
 Re: 544 Farmall in reply to K.B.-826, 04-03-2007 19:50:17
Thank you for your reply. I will give my father the information! ;-)
