Re: 303
Armand Tatro
04-03-2007 16:31:21
Might want to check your S.N. Back in the '60's we had a very early 303 (only 4 digits in S.N.) and I want to think it had a BD220 cid engine in it. I do know that when we needed parts we needed the S.N. as there were so many changes and upgrades. How long have you had your 303? Armand
Owen Aaland
04-03-2007 21:20:16
 Re: 303 in reply to Armand Tatro, 04-03-2007 16:31:21
You may be correct in the change from BD-220 to C-221. I thought it was during the 101 production run but it may have been during the 303s.
Easiest way tell the difference is to look at the governor. BD-220 came out the side of the front cover, C-221 mounts in the back of the front cover.
I know there was at least one 303 with a BD 220 in it because I put it there. Mine threw the flat belt and it got wedged in the pulley housing. Flattened the rear main bearing and twisted the block.
