M wont start after rain
eshoreboy
04-04-2007 08:43:45
i put my m a m,y house last night with ther barn not up yet and i put some tarps over her pretty good, but this morniong when i went to start her she would not do anything, but turn over..so what can i look for and im thinking i got water down into the dist. so what to do?
Thanks alot
Nawlens Gator
04-04-2007 11:04:53
 Re: M wont start after rain in reply to eshoreboy, 04-04-2007 08:43:45
The black plate is a dust cover. I grab one of the raised knobs with channel locks and gently pull it out. They break pretty easily so be gentle. I keep a couple on hand.
I used to have to dry the points and distributor cap on one of my tractors after a rain. Switched to electronic ignition and haven't had a problem since.
Sheepdog in NE
04-04-2007 18:10:11
 Re: M wont start after rain in reply to Nawlens Gator, 04-04-2007 11:04:53
If you put in the electronic ignition it will solve any future problems with moisture.
eshoreboy
04-04-2007 09:53:00
i got her statred finally with my moms hair drier, but i have anothor question i have the vertical dist. and i got the cap off and the black case benith that(dont no what its called) i could not get that out. How do you do it. it looked like to me its fastend in there tight.
glennster
04-04-2007 13:51:03
 Re: M wont start after rain in reply to eshoreboy, 04-04-2007 09:53:00
if you have a vertical distributor, it is probably a delco, they were used to change from a magneto to breaker point ignition. the tune up kit is different than the regular ih kit.
old
04-04-2007 10:15:56
Most tractors have that points cover on them. Yes they can be a pain to get to pop loose. What I do is tap them with the handle of a screw driver to get them loose. Don't tap to hard and when you tap sort of tap up words so it will come up when tapping on it
Rich-Wisc.
04-04-2007 10:09:08
That plate should come out by grasping the raised portion of it. It may have some corrosion under it that is preventing it from coming out. Spray some WD-40 around the outside edge of it and let it work awhile, then try again. If it dosen't move, you can take a flat tipped screwdriver and try to pry it out or take a hammer and place the tip of the screwdriver on raised portion of plate and lightly tap on it to try to break it loose. Good luck.
CENTAUR
04-04-2007 09:34:29
Look into the distributor cap as it has may have moisture due to being covered up while still warm.Dry with a propane torch or remove and give it a few minutes in a oven.Check to see if the distributor vent hole is open.If rain got to it you can prevent this from happening again by covering with a plastic bag of your choice.If the cap has dull ozone look you can clean with a good carb cleaner and rinsing with clean hot water.That will make it like new again unless it already has a burned hair like line between two termnals inside the cap. CENTAUR
