Tire PSI
1951farmallh
04-04-2007 14:26:41
What should the PSI be of the rear 12.4-38 tires on a Farmall H? right now it is at 10 PSI. Thanks.
1951farmallh
04-04-2007 18:53:22
 Re: Tire PSI in reply to 1951farmallh, 04-04-2007 14:26:41
Thanx for the replies, i'm driving my tractor on the road tomorrow and wanna make sure everything is safe and in tip-top order.
NDS
04-04-2007 17:47:29
We always tried to run 15psi annything in 10/15psi range is fine.
HAS
04-04-2007 14:53:43
I use 10-12 psi. My son aired them up to 24 once and a rusted spot on the rim blew out, so don't go any higher than you have to.
