1961 B414 Starter needed.
goldhunter
04-05-2007 12:38:28
My dad has a 1961 b414 that is engaged with a lever, not a solenoid. What other starters will work? His has a broken housing around the gear. Are there any later starters that will work? He will convert to electrical solenoid if necessary. Any info helps, or if you have a starter that helps too.
Fromjb2
04-05-2007 13:23:54
 Re: 1961 B414 Starter needed. in reply to goldhunter, 04-05-2007 12:38:28
Hi Gold, the individual gear housing is a separate part available from CNH. I posted a picture in Parts & Pieces of starter parts page.
Now it could be a Delco Remy or Lucas starter.
B275 Diesel would have same starter. 434 would have newer model requiring key switch start.
Check CNH parts web site.
JimB
