1586 switches
jim malla
04-05-2007 12:50:19
can someone tell me where the safety switch is on the 1586. tractor wont start with clutch in. plenty of power to battery. just wont start. help!
RR Mech
04-05-2007 20:19:25
 Re: 1586 switches in reply to jim malla, 04-05-2007 12:50:19
the late ones had two. One goes thru the cowl and actually touches right on the clutch pedal the same as the early ones.The late ones also had one under the seat area and was acuated by the park lever. Either one would let the tractor start.
Jay IH man
04-05-2007 16:02:24
Early 86 series had switch on firewall above clutch pedal on engine side,late have them under seat on range trans linkage on right hand side of unit.
Tom in Michigan
04-05-2007 15:31:27
Jim, not sure about the clutch safety switch. Our 1086 will not start unless the range selector is in park. Our clutch does not have to be disengaged to start the tractor; however, the previous owner may have disabled it. Tom
