IH 200 spark plugs
Don Anderson
04-06-2007 09:44:40
Bought an IH 200 with belly mower a couple weeks ago and decided I would change the spark plugs. The tractor has sat outside and the two front plugs will not budge even with a 18" breaker bar. I have sprayed the plugs with Kroil and WD 40 and they will still not budge. Threads on the back two plugs that I got changed were really dry and put a little antiseze on the threads before reinstalling. Any suggesions on how to get the other two plugs changed? Can I apply a little heat or will this make the glass on the plug explode? Will welcome any suggestions.
Joe Schmitt
04-06-2007 09:58:26
 Re: IH 200 spark plugs in reply to Don Anderson, 04-06-2007 09:44:40
If the motor runs with the old plugs try running it until it`s up to operating temp and keep penetating oil on them ,the heat should draw the penetrating oil down around the threads. Try removing them hot. I would be patient with them, especialy if it`s running yet.
