Special to City Boy Mccoy
Tom Windsor
04-07-2007 11:39:43
third party image
This is my toy that you keep asking about. I have tomatoe plants in there 6 feet tall and tomatoes little bigger than golf balls.
(My neighbor, who does this seriously with serious large buildings...keeps poking fun at my toy)
tw
Andy Motteberg
04-14-2007 12:52:26
 Re: Special to City Boy Mccoy in reply to Tom Windsor, 04-07-2007 11:39:43
A RADIATOR TANK????? ?? BEFORE IT WAS A SHED??
SuperA-Tx
04-07-2007 19:50:34
Tom,
Got 45 of those houses at the farm that are 40X100 and another six at the retail store. I think we might need them tonight cause its suppose to get clsoe to 30. We even had a little snow this morning.
You got an exhaust fan in the other end?
Tom Windsor
04-07-2007 20:15:31
 Re: Special to City Boy Mccoy in reply to SuperA-Tx, 04-07-2007 19:50:34
My neighbors around here have those units about 45 X 100. But nothing on the scale that you mention. One of them has 6 and the other one 4. They are family operations and just these units keep them real busy. The one with the 6 does flowers. The other one has tomatoes in one and the other three are devoted to various garden plants that they wholesale--tomatoes, peppers, cabbage, etc etc.
So, having said that, I am aware of the time and effort that they put into this small operation compared to yours. I cannot imagine the amount of labor required to keep your operation up and going.
I was wondering...when you replace the plastic on your buildings, how do you attach it at the bottom on each side? A friend of mine operates a plastic extrusion company and I got from him several hundred feet of plastic strip about 3/4 inch wide with holes in it. The stuff looks like the tape that plumbers use to hang pipes with...has holes down the middle the same way. We used this as a test on the neighbors replacement and it worked very well.
TW
SuperA-Tx
04-08-2007 10:30:39
 Re: Special to City Boy Mccoy in reply to Tom Windsor, 04-07-2007 20:15:31
We replace the plastic on ours every year but some people do use a two year plastic. We just use ours as cold frames so its better to take the plastic off every year than to have to get exhaust fans and the expense of running them.
Our houses have 2 X 6's on the bottom and we use what is called "batten" tape to secure the bottom and ends. Batten tape is a woven plastic that is 3" wide and comes in rolls 300 feet long. Then we use staples about every 3". We also throw some of the tape over the houses to keep the wind from popping the plastic loose. The straps over the house we use roofing nails to hold them in place.
Some houses use an aluminum type of fastener to hold the plastic that has a wedge in it that locks the plastic in. You can get it for single plastic, double plastic and even some that hold two plastics and shade cloth.
Its quite an operation getting all the houses covered each year, not to mention the expense.
The houses with liners we use modine heaters in them. At the retail store three are heated but I dont keep much heat in them. Its just gotten so expensive to heat the things its cheaper to let some things die and get new plants to sell rather than holding them over. The three houses have four foot exhaust fans I just run in the Spring before I take the plastic off.
Tom Windsor
04-07-2007 20:04:37
Yes I have exhaust fan that is connected to thermostat. off and on and maitains temp pretty good.
I am trying to figure how to keep it warm this winter without spending a lot of money.
Andy Motteberg
04-07-2007 18:43:44
Looks like it would make a nice tractor shed! ha ha.
