Hough #30 Payloader
regan
04-07-2007 17:43:22
Replaced engine, starter, new batteries. Engine seems to be free. Engine turns over slowly and will not start. Replaced battery cables and even used boosters and still no luck. Need HELP!!!
Tom B (tbone)
04-07-2007 18:48:59
 Re: Hough #30 Payloader in reply to regan, 04-07-2007 17:43:22
Make sure you have a good clean ground connection ideally a mounting bolt on the starter. I have an H-60 that the ground was to the frame so I ran a cable from there to the starter and it helped.
Tom
regan
04-07-2007 19:36:21
 Re: Hough #30 Payloader in reply to Tom B (tbone), 04-07-2007 18:48:59
Checked grounds. Even have cable hooked to end of starter. Still no luck. Agreed,seems to me like bad ground. Guess we will keep looking. If you think of anything else, speak up!!! Thanks in advance.
