Farmall 450 belt pulley gear box
Darin Brooks
04-07-2007 18:01:56
I kneed to know if the belt pulley gear box off a Farmall 460 will fit a Farmall 450. Thanks.
Jossette
04-07-2007 18:52:01
 Re: Farmall 450 belt pulley gear box in reply to Darin Brooks, 04-07-2007 18:01:56
M
SM
400
450
Wardner
04-07-2007 18:37:06
Just as H and M use different belt pulley gear boxes, so do the 460 and 450. The pulley itself is interchangeable.
Darin Brooks
04-07-2007 19:42:07
 Re: Farmall 450 belt pulley gear box in reply to Wardner, 04-07-2007 18:37:06
Thanks for the info. It will save me a lot of time and searching.
Wardner
04-08-2007 06:10:11
 Re: Farmall 450 belt pulley gear box in reply to Darin Brooks, 04-07-2007 19:42:07
If you want to save time, see me for the large frame gearbox. I have a new old stock gearbox that I bought for the pulley. I am keeping the pulley.
You will be better off getting one locally because they are heavy and costly to ship. They should be very easy to find at salvage yards in your area.
Darin Brooks
04-08-2007 13:45:45
 Re: Farmall 450 belt pulley gear box in reply to Wardner, 04-08-2007 06:10:11
Where are you located and how much do you want for the NOS gear box!
Wardner
04-08-2007 13:59:03
 Re: Farmall 450 belt pulley gear box in reply to Darin Brooks, 04-08-2007 13:45:45
You got mail.
georgeky
04-08-2007 09:18:04
I have one on a 350, one on a H,M,400 and 450 and they all have a different number on them. Won't one off the 350 fit the H and the one from the M fit the 400/450 and so on?
Wardner
04-08-2007 14:03:10
 Re: Farmall 450 belt pulley gear box in reply to georgeky, 04-08-2007 09:18:04
The M and 400 gearboxes will interchange (bolt up) but the engagement levers are 180 degrees offset. If the lever is opposite of what you need, the weld can be cut and rewelded for the correct orientation.
