Got a hole in the ole manafoild
eshoreboy
04-07-2007 18:39:37
I was runnin the old M today with the hood off(workin on the ALT) and i was looking over it while she was runnig, and i saw fire in the manafoild. Its in the middle of the manafoild and its about the size of a quarter and a nickle. I wa just wondering is this a problem i have to fix right away or can i get it stirght when the time is right(will it cause any prblems)
Thanks Ryan
Owen Aaland
04-07-2007 22:13:31
 Re: Got a hole in the ole manafoild in reply to eshoreboy, 04-07-2007 18:39:37
Does your exhaust pipe bolt on rather than a pipe screwed in? It sounds like you have a kerosene manifold instead of a gasoline manifold. I think the hole you are seeing is from a soft plug that should be installed there. Find a dish style soft plug and reinstall it in the hole.
old
04-07-2007 20:48:19
You will most likely be ok but, if something gets in that area it can also cause a fire. If it where my tractor I would at least try to cover it some even if you had to use a beer can to make the cover. Ya I have an H that is wearing a beer can on its exhaust manifold just to help keep junk out and the noise down
Tom Windsor
04-07-2007 19:24:22
It would cause me brain damage thinking about it. With a hole that large, it would seem to me to be very loud. It will probably run as long is the cracking does not progress into the intake area.
TW
Aaron Turnage
04-07-2007 18:47:42
well I have two holes in my B allis Chalmers manafold they been there for 6+ years and they havent hurt it
