160 degrees on a C-123 block! :)
Patrick Martin
04-07-2007 22:12:53
Hey guys, would you say 160 degrees is too hot for a C-123 (Farmall SA,100,etc)???? I just got mine up to this the other day while shredding a 3 acre section. I always watch it pretty close and am just curious to know if this seems too hot for the little engine. Anyone know?????
On another note I have to pull my head again. Either I have a bad valve stem seal or one of my valves is leaking for some reason. Weird because I just worked over this head myself and installed new stems, valve, and all from one of the kits available from this site.
While I was running one day I noticed smoke coming out of the oil filler/breather pipe (tube on valve cover) and chugging in tune with the exhaust!!!! HA! Imagine that! :)
I keep on having little troubles with this little 100 but man I sure do love it! Working out the kinks on this thing is a sheer pleasure!!!! :)
HAPPY EASTER GUYS!!!!! !!!!! !!!!! !!! :)
georgeky
04-07-2007 22:38:06
 Re: 160 degrees on a C-123 block! :) in reply to Patrick Martin, 04-07-2007 22:12:53
That is good. They can run safe to 200. My old M runs at 190 pulling a 10 foot disk.
Bob
04-07-2007 22:37:17
"While I was running one day I noticed smoke coming out of the oil filler/breather pipe (tube on valve cover) and chugging in tune with the exhaust!!!! HA! Imagine that! :)"
I hate to tell you but the "chugging" of smoke out the crankcase breather is MUCH more likely to be sneaking past a piston than past a valve guide.
Patrick Martin
04-07-2007 22:42:28
 Re: 160 degrees on a C-123 block! :) in reply to Bob, 04-07-2007 22:37:17
"That is good. They can run safe to 200. My old M runs at 190 pulling a 10 foot disk. "
Fantastic!!!!! Thanks for the reply! I was kinda curious as to this :)
Bob
04-07-2007 22:40:53
P. S....
As long as the coolant isn't boiling; you're not going to hurt the engine. Getting the temp up into the 180 to 195 range is BETTER for the engine than running cold.
Patrick Martin
04-07-2007 22:47:24
 Re: 160 degrees on a C-123 block! :) in reply to Bob, 04-07-2007 22:40:53
"I hate to tell you but the "chugging" of smoke out the crankcase breather is MUCH more likely to be sneaking past a piston than past a valve guide."
You're right Bob! I forgot about the bottom end! It could be possible I broke a ring. Hmmmmm?
Now I did do a compression check the other day and got 90psi across all four. I didn't do a leakdown check though.....Guess I need to do that tommorrow. :)
Patrick Martin
04-07-2007 22:50:45
 Re: 160 degrees on a C-123 block! :) in reply to Patrick Martin, 04-07-2007 22:47:24
"As long as the coolant isn't boiling; you're not going to hurt the engine. Getting the temp up into the 180 to 195 range is BETTER for the engine than running cold. "
Yep I know it needs to be hot to maintain combustion but I wasn't sure what the parameters of this cooling system were. I wish I could find an IH specified temp range for this little engine. :)
Bob
04-07-2007 23:49:15
 Re: 160 degrees on a C-123 block! :) in reply to Patrick Martin, 04-07-2007 22:50:45
In the "old days"; before "permanent antifreeze" was in common use; they tried to keep coolant temperatures down so as not to boil away the antifreeze.
As long as the temp stays below the point where the coolant will boil in "hot spots" in the engine you aren't going to hurt the engine; and the engine will probably burn cleaner AND last longer.
That pretty much applies to ANY liquid-cooled engine.
Patrick Martin
04-08-2007 00:34:22
 Re: 160 degrees on a C-123 block! :) in reply to Bob, 04-07-2007 23:49:15
I'm still in the process of cleaning this block too so that might have something to do with it. I've been running an acid flush through it pretty regular now and have been getting lots of crud out of the block.
I'm gonna do a leakdown test then go ahead and pull the head and see what I have going on in there. I'll drain the oil tommorrow and run some deisel in the crankcase to clean it out and then see what we can see.
