clutch problem ?
Don Benson
04-08-2007 07:38:54
I have an IH 300U I have adjusted the clutch per the IT book but occasionaly (especially going up hill) something will start slipping and whirring. I have the TA transmission and putting it in TA stops the problem, any Ideas?
Don Benson
04-08-2007 09:38:39
 Re: clutch problem ? in reply to Don Benson, 04-08-2007 07:38:54
I'll try to re adjust the clutch, how can I tell if it is the engine clutch or the TA clutches
Steven@AZ
04-08-2007 11:57:24
 Re: clutch problem ? in reply to Don Benson, 04-08-2007 09:38:39
If it is the engine clutch you should have the same problem whether the TA lever is ahead or back.
If it is the TA clutch, the problem/slipping will go away when you pull the lever back.
Steven@AZ
04-08-2007 08:45:33
Sounds to me like the TA clutch is bad - when you get under a load the TA clutch starts slipping and it goes to low range.
First thing I would do is make sure the TA and clutch linkage is adjusted PERFECTLY by the book!
After that to check for sure I would do the following: Drive in 5th gear with TA lever ahead (direct) until you hear/feel the slipping. Pull the TA lever back and keep going, if there is no more slipping/noise try stepping on the brakes a little bit. If you can't make anything slip with the TA in low range (pulled back) then it must be the TA clutch that is bad.
Steven@AZ
04-08-2007 08:44:37
To check for sure I would do the following: Drive in 5th gear with TA lever ahead (direct) until you hear/feel the slipping. Pull the TA lever back and keep going, if there is no more slipping/noise try stepping on the brakes a little bit. If you can't make anything slip with the TA in low range (pulled back) then it must be the TA clutch that is bad.
Allan In NE
04-08-2007 07:47:46
Yep,
Bad clutch.
Allan
