can I interchange the C123 with the C135 engine?
Jim Christophel
04-08-2007 19:47:00
I have a Farmall Super C tractor that I need to put new block in. A friend of mine has a complete C135 engine. My question is, can I interchange the C123 (Super C engine) with the C135 engine? I have been told the blocks are very similar and may match up on the tractor. Thank you for your help.
Hugh MacKay
04-09-2007 03:13:29
 Re: can I interchange the C123 with the C135 eng in reply to Jim Christophel, 04-08-2007 19:47:00
Jim: As Bill mentions, C-135 engines from 330, 340 tractors do not have the crank drilled for the pilot bushing needed in your Super C. You may run across the same with other C-135 engines. If you searce the archives there are a couple of threads where this hole has been drilled in a C-135 crank.
Another item you might look into is water pump and fan. Most C-135 engines have automotive type water pump on the fan hub. Check it out, but I think you can use your SC water pump and fan. Even the 140 and 240 with C-123 engine have the automotive type water pump. I have both type water pumps in my 130 and 140. I think you could also use the automotive pump if you have the right shroud. The difference is not great and as Bill said, a bit of modification will do the trick.
Bill Newhart
04-08-2007 20:10:29
I have a Super C with the 135 engine conversion and its a great machine. My C135 came from a combine so the flywheel was no problem, but someone told me that if the engine came from a 340 farmall the flywheel might have to be changed because of the Independent PTO system. Otherwise the engine just bolts right up - the radiator was a problem from the combine engine and the old Super C radiator just didn't fit so that required a little work. Great idea Fun Job.
