Solution for a sticky starter...
Jesse
04-09-2007 18:12:32
My 400 starts easy enough, but I have noticed that the bendix has a tendency to want to stay engaged on the starter. I need this fixed as I don"t want to have to replace the ring gear any time soon. What do I need to use to lubricate this (hard grease, WD 40, etc.)? What is the proper way to lubricate this starter so it will prevent sticking in the future?
Farmallkid From Ont,
04-10-2007 06:13:20
 Re: Solution for a sticky starter... in reply to Jesse, 04-09-2007 18:12:32
Spray some GIBBS in there, that stuff won"t dry out, we find thats the best stuff since sliced bread!
Pete7
04-09-2007 19:20:35
Hi Jesse...Not sure if a 400 uses the same starter bendix as a Super A, but I bought the new tpye bendix from my IH/case dealer. The part # was CAS 77695H. Cost $66.94 and it has worked well for me for about 1 year now. Pete
vally farm
04-09-2007 19:17:50
I was having the same thing. I had some old spray lithium greese laying around. Sprayed it 2 yrs ago in mid summer, haven't had it bind up again since. Mike
Michael Soldan
04-09-2007 18:22:48
I agree with Janicholson, hard grease may cause headaches in extreme cold weather and WD40 shouldn't be used on anything, its one of the poorest lubricating devices on the market, it will dry out within days and you are right back where to started. Use a light oil like "3 in 1", but a relacement bendix is likely the answer.
Janicholson
04-09-2007 18:15:30
There is a new drive/bendix available from CaseIH that actually cures the problem, I recommend that as a permanent fix. JimN
Jesse
04-09-2007 18:30:30
 Re: Solution for a sticky starter... in reply to Janicholson, 04-09-2007 18:15:30
Thanks for the info. I will look into it. I don't suppose you would have a part number handy or is this something the parts guy should know at the counter? I want to make sure I get the right part and not some cheap after-market crap.
Janicholson
04-10-2007 06:34:18
 Re: Solution for a sticky starter... in reply to Jesse, 04-09-2007 18:30:30
The correct item is described as: Clutch style Starter drive, replacing the older inertia drive. I do not live near my tractors, sorry. JimN
