560 or 660
Ryan Brumley
04-09-2007 23:08:57
Hello,
I recentley bought what i thought to be a IH560. I thought it was a 560 because it had 560 badges and the guy selling it said it was a 560. now apon further inspection the id tag says the model is 660 L and the seral # is 2323 c-s-y now if i am not mistaken that makes it a 660 but why the different hood? If anybody has any info on these tractors i would like to hear it all.
Wardner
04-10-2007 00:25:46
 Re: 560 or 660 in reply to Ryan Brumley, 04-09-2007 23:08:57
Without looking at my parts book, I'll say the hoods are the same. The only difference in the sheet metal are the dog legs and badges. The 660 legs are extended three inches to accommodate the taller radiator. There is also a cast iron trim piece below the grill. 660 has a six blade fan; the 560 has a five blade fan. The biggest difference is the planetary hubs on the 660. Its hard not to notice them. The tachs should be different because the engine is set for 2400 vs 1800 rpm even though the diesel injection pump and injectors are the same. The remaining differences are the rear tires, rims, wheels, and gear ratio at the differential. The 660 weighs close to 1800 lbs more than the standard tread 560. It has 20 hp more, too. I have pretty much covered everything.
