Painting Farmall Rims
John P.
04-10-2007 16:31:19
What kind of paint or other coating is recommended to paint the rims with? Normally I see them painted some kind of silver or grey, but what kind and color silver or grey? What brand seems to work best and is most durable?
Roger Mills
04-11-2007 14:24:55
 Re: Painting Farmall Rims in reply to John P., 04-10-2007 16:31:19
Rust-O-Leum also has a 'hammered' look version of the aluminum paintthat just sprays on and looks exactly like galvanizing. ( I think, anyway). I did inside and out.
John P.
04-11-2007 15:48:58
 Re: Painting Farmall Rims in reply to Roger Mills, 04-11-2007 14:24:55
What about the actual Rustoleum cold galvanizing compound?
georgeky
04-11-2007 12:29:18
Rusty Farmall has the right plan. I brush all my rims and they turn out great. I ask local IH shop years ago about the paint for rims and that is how they done it.
John P.
04-11-2007 15:50:23
 Re: Painting Farmall Rims in reply to georgeky, 04-11-2007 12:29:18
Does it come out clean or can you see brush marks?
Farmallkid From Ont,
04-11-2007 07:32:53
We have painted rims on 3 tractors now, and i'm not happy with them,We tried the aluminum rattle cans from the hardware store on 2 tractors, it rubs off, the case silver will go blackish, and the aluminum wipes off, we mixed the 2 cause when mixed it dosn't go black, but still wiped off a little, So the next one we do, i will get automotive paint, and put hardener in it, then it wont come off.
RustyFarmall
04-11-2007 03:25:55
Get a quart can of Rust-Oleum aluminum and a good soft brush and have at it. That is how it was done back in the fifties at the dealer who was doing the IH sponsored up-grades. If it was good enough for IH, it's good enough for me.
John P.
04-11-2007 15:47:14
 Re: Painting Farmall Rims in reply to RustyFarmall, 04-11-2007 03:25:55
I never knew they were aluminum paint!
gmsupera
04-10-2007 19:10:54
I am restoring my first little red toy and loving it. when I got to the rims I used PPG DAR 4023 with DXR 80 hardner they came out nice good luck
CNKS
04-10-2007 17:40:46
Brand is not important, the type of paint is. Acrylic urethane over epoxy primer is the most durable, rims or elsewhere. You must use hardener with it, which requires supplied air to avoid breathing the isocyanates in the hardener. I use PPG 8568, but that is only my opinion. The rims were originally galvanized so there is no official paint code.
Tom Windsor
04-10-2007 19:13:16
 Re: Painting Farmall Rims in reply to CNKS, 04-10-2007 17:40:46
Please help me out here...and I will learn something new today...Apply it with "supplied" air?
Do you mean to the face mask?
TW
CNKS
04-10-2007 19:35:09
 Re: Painting Farmall Rims in reply to Tom Windsor, 04-10-2007 19:13:16
Yes. Cartridge masks will not filter out isocyanates, unless the cartridges are brand new and the mask fits perfectly, not likely. Consists of an intake blower or turbine set out of the fumes, a hose, and a mask or hood.
Tom Windsor
04-11-2007 20:31:21
 Re: Painting Farmall Rims in reply to CNKS, 04-10-2007 19:35:09
I think I want this system. Can you make a recommendation as to a manufacturer that you find that works good? I do a lot of spraying and I think this would work best for me.
TW
Jossette
04-10-2007 17:38:28
take them to the sandblaster and have them put a coat of primer on when they are done..
GordoSD
04-10-2007 16:38:24
This has been discussed about 10 times in the past 6 months. Please check the archives. IHC Argent Silver enamel with hardener works pretty well. But I spent over 25 hours and 50 dollars in materials prepping mine for paint.
Gordo
