Getting bolster bushings out
Randy as in Ran
04-10-2007 18:50:32
Hi All , I ordered all the bushings , seals and thrust washer today so now I need to get the bushings out of the bolster . I was thinking of using a air hammer . I'm assuming the bottom one comes out the bottom and the top one comes out the top . Does anyone have an easy surefire way to remove these bushings as painlessly as possible ? Thanks ! ...Randy
BTW- this is on a M .
Janicholson
04-11-2007 06:48:42
 Re: Getting bolster bushings out in reply to Randy as in Randy-IA, 04-10-2007 18:50:32
A muffler cutting chisel (NAPA and others have them) is flat in cross section, has a recangular but cup shaped cutting end, and has a bend in the middle. when used to remove pipes, it removes a curl of metal down the length of the overlapping joint on the pipes, relieving pressure to allow reuse of the inner pipe. they work great for this and many other uses. Indespensable. JimN
williamf
04-11-2007 04:30:24
I used much the same method as BobM, but since I don't have an air hammer I used a small cold chisel.
Good luck, Wm
JTinNJ
04-11-2007 00:38:17
I can't do anything without getting hurt.So,I'm not going to tell you how I've done it.
MN Scott
04-10-2007 20:14:40
I've found the gas wrench works the best to remove bushings. For it to work they have to be steel backed. Just heat the edge and hit the O and you'll burn thru in a second. You will not hurt the casting as it will not have time to get hot.
Fancy Farm
04-10-2007 19:37:56
I was kind of reluctant to tell anyone my method of removing the top bolster bushng but I think mine is the safest method offered yet. Try using a sawsall and a fine metal cutting blade and just cut through the brass bushing works for me.
Bob M
04-10-2007 19:10:01
Randy - I had good luck on my Super H using an air hammer with a chisel bit to cut thru the bushing shells lengthwise. Then simply collapse the cut bushings with a big screwdriver and pull 'em out.
flying belgian
04-10-2007 19:09:29
Torch.
