Woods Mower Problem
KY Farmall
04-11-2007 17:37:58
The Woods belly mower on my Farmall A has developed a belt problem. Since putting a new belt on last summer the belt is wanting to roll over and run upside down on the drive pully. All of the adjustments and tensions have been checked and rechecked and seem to be just fine. After coming out from under the front V-idler pully it can't seem to maintain the half twist up to the drive pully. Within just a few seconds of engaging the PTO it rolls over. The one thing I've noticed is that comparing it to the old belt I removed last summer it appears that the new belt does not have as deep of a V to it. If that is the case it would not have enough grip depth to hold it adequately in the drive pully after the short half twist. I got the belt at my local International/Woods dealer as I have all previous belts. I'm just wondering if anyone else has had this problem. Are the belts not quite the dimensions they originally were? I've used this mower for years and never had this problem.
Thanks,
John in KY
Farmall A, International Cub
Sagebrusher
04-12-2007 06:41:40
 Re: Woods Mower Problem in reply to KY Farmall, 04-11-2007 17:37:58
KY One thing you might try is reversing the twist on your belt. i.e. if you installed it with a twist to the right, remove it and install it with a left twist (opposite direction.) This MAY give it the rotation direction it needs to function properly. Hope this makes sense but perhaps it is just twisted wrong. I've had overall better luck with tractor dealer's partsmen than I have with auto supply houses
gene bender
04-11-2007 18:49:17
That pulley should be a flat one so the belt doesent have to twist going to the driver leaving the driver should be v-shaped. You dont want the belt to twist going and coming from the driver get a flat idler and you will be o.k. From a user of WOODS mowers since 64. I have sold new ones traded for used ones and so forth.
RustyFarmall
04-11-2007 17:48:49
The Woods mower under my H requires a half twist on the left side, and a 3/4 twist on the right side. If it is wrong, the belt will not stay on.
