Power steering help needed - Farmall
Easy1
04-11-2007 18:57:15
I am looking for a Char Lynn power steering unit for my 48 H. Will a unit for the 400 fit on my H? I was told it mounted up to the govenor case. Would this require a seperate pulley? I am not at home right now, so I cannot go and look at the H. Thanks.
Easy1
04-11-2007 20:17:04
 Re: Power steering help needed - Farmall in reply to Easy1, 04-11-2007 18:57:15
Thanks - I really appreciate the info!
Steven@AZ
04-11-2007 20:10:04
You can use the torque generator/motor, that's about it from an M thru 450...
GordoSD
04-11-2007 19:44:21
Are you sure you need it? I just did a light disc on some cattle feed lot land yesterday with an H wide front and it just purred around there, steered easy and it did not have PS
Gordo
Allan In NE
04-11-2007 19:31:20
No, that won't work on your H.
The lower radiator hose is in the way. Steering shaft is different, the torque motor mount won't work either.
Look for a unit off of a 300 or 350.
Allan
