how do check oil in a 4366??
eric schroeder
04-11-2007 19:07:25
how do you check oil level in front and rear differentail housings????i assume the front differentail,transmission splitter and hyd system are all sharin the same oil???
Janicholson
04-12-2007 04:30:16
 Re: how do check oil in a 4366?? in reply to eric schroeder, 04-11-2007 19:07:25
Two short answers:
Stick your finger in the fill hole if you can feel oil with one joint bent down it is full. if not fill it till it runs out.
Use the info in the manual. Good luck. JimN
