574 brakes
makin'hay
04-12-2007 08:27:45
i have an IH574 Deisel. the left brake works great but the right one go"s to the floor. doesnt matter if i pump it or not. is there any way to bleed these ? cant seem to find a bleeder or a brake fluid reservoir. do the brakes use hyd oil from hyd tank? i just bought this tractor. thanks
maplehillfrm,pat
04-12-2007 09:30:50
 Re: 574 brakes in reply to makin'hay, 04-12-2007 08:27:45
I think that may be like my 454 I had, to bleed the brakes there are two bleed fitting on the rear end of the axle if I recall towards the top of the axle between the wheel and the housing, pat
makin'hay
04-12-2007 09:56:23
 Re: 574 brakes in reply to maplehillfrm,pat, 04-12-2007 09:30:50
youre correct. i found them there. THANKS
