clutch?
boochie
04-12-2007 08:44:32
REPLACED CLUTCH PRESSURE RELASE BEARING IN A SUPER C
WENT TOGETHER FINE U CAN PRESS PEDAL AND FEEL IT RELEASE PLACE THE TRACTOR IN GEAR AND TURN WITH HAND CRANCK TIRES MOVE DEPRESS PETAL AND TIRES DO NOT MOVE!!!!! !!!!! !!!!! !
I START THE ENGINE AND PRESS CLUCTH U CAN STILL FEEL IT RELEASE BUT U CAN NOT GET IT IN GEAR BECAUSE OF SCRAPPING!!!!! !1
DO I NEED TO ADJUST BOLTS IN PRESSURE PLATE OR DID IT COME ADJUSTED AND I HAVE ANOTHER PROBLEM?
HAVE ADJUSTED CLUTCH ROD ALL THE WAY OUT AND I AM ALMOST SURE WITH EVERYTHING NEW IT SHOULDN'T BE THAT WAY AS IT ALLOWS FOR NO ADJUSTMENT IN THE FUTURE ----- ---I WOULD APPRECIATE ALL YOU HELP.
BOOCHIE IN N.C.
Red Dave
04-12-2007 11:30:31
 Re: clutch? in reply to boochie, 04-12-2007 08:44:32
Did you adjust the fingers on the pressure plate to specification before you installed it?
This where you lay it face down on a flat surface and measure the height of each fimger. The procedure is detailed in the Blue Ribbon Service Manual.
If they are not in spec and even, clutch adjustment will be way off, or maybe impossible.
44 massey
04-12-2007 10:17:21
Are you sure you didnt put the disc in backwards????? ?
boochie
04-12-2007 10:58:16
 Re: clutch? in reply to 44 massey, 04-12-2007 10:17:21
JUST WENT AND CHECKED DISC IS IN CORRECT THANX BOOCHIE
A. Bohemian
04-12-2007 09:40:09
 Beginning? in reply to boochie, 04-12-2007 08:44:32
Why did you find it necessary replace the bearing; in other words, what went wrong in the FIRST place?
boochie
04-12-2007 10:55:17
 Re: Beginning? in reply to A. Bohemian, 04-12-2007 09:40:09
IT WAS MY "POP'S" TRACTOR AND I AM RESTORING IT
TOOK IT APART AND REPLACED SEAL AND HE HAD ADUSTED IT SO MUCH THAT THE FINGERS ON THE PRESSURE PLATE WERE RAZOR THIN
WHILE IN THERE I REPLACED EVERYTING BOOCHIE
CENTAUR
04-12-2007 09:21:51
Your release bearing had different dimensions from the original? CENTAUR
kfox
04-12-2007 11:08:53
 Re: clutch? in reply to CENTAUR, 04-12-2007 09:21:51
I replaced the clutch in a H last year and had the same problem. I finally found the splined center of the new disk was a little longer than the old disk and the splines on the shaft had a small shoulder where the old disk had run. A little polishing On the shaft splines with the Dremil tool and everything was fine. ken
