Re: 806 transmission
the tractor vet
04-12-2007 17:03:48
First check and make sure that nothing is binding the shifter under the cowl . As for getting to the rest son you is in for a bunch of work . Ya either have to remove the fuel tank or support it and remove the whole dash support drain the cooling system and Hope the temp. sending unit comes out along with ALL the sheet metal wires hyd. like if it has the side mount for culivators Also check and make sure that one of the Tapered grove pins did not come part way out and get caught down by the speed trans cover at the collar as i have seen this happen more the once.
chris n
04-12-2007 17:44:16
 Re: 806 transmission in reply to the tractor vet, 04-12-2007 17:03:48
I also forgot to mention, Reverse DOES work. I just can't change out of 3rd.
chris n
04-12-2007 17:40:01
we just got the tractor, so i need to look into it a little more, but thanks for the tips
