Fast Hitch part dimensions?
tractorsam
04-13-2007 03:22:06
I'm looking for the dimensions of the rod that is used to raise and lower the front of the Fast Hitch (for when ploughing). Mine has the tube it slips into but not the rod I need to connect it to the touch control. If anyone has one they could measure that would be much appreciated. Many thanks, tractorsam
Haas
04-13-2007 07:42:07
 Re: Fast Hitch part dimensions? in reply to tractorsam, 04-13-2007 03:22:06
Are you talking about the one for the 140 one point hitch. If so, I could send you a picture. I bought mine new about a year ago. Could look up and let you know the source. These are a little tough to make, as the end that attaches to the rockshaft must have just the correct bend so that it does not bind against the rockshaft when in the forward position.
tractorsam
04-13-2007 08:24:10
 Re: Fast Hitch part dimensions? in reply to Haas, 04-13-2007 07:42:07
Thanks for the offer but although the part does the same job I'm not sure it's the same between the 140 and the Super C. Thanks, tractorsam
georgeky
04-13-2007 09:25:50
 Re: Fast Hitch part dimensions? in reply to tractorsam, 04-13-2007 08:24:10
The dimensions I gave you are from a Super C.
georgeky
04-13-2007 05:08:56
It is 24 15/16 inches from end to end. It is 1 3/16 in diameter. The hole for the touch control arm is centered 3/4 of an inch from the end, with the next hole 5 5/16 from center to center and the other hole is 16 3/4 of an inch from there.
