Service valve
JtinNJ
04-13-2007 06:24:55
I have a 966. The service valve is stuck in the open position. My question is, what is the best way of getting it to move without doing any damage?
JTinNJ
04-13-2007 07:11:39
 Re: Service valve in reply to JtinNJ, 04-13-2007 06:24:55
I guess a little more info would have helped. The hydraulic valve is stuck in the open position. It's under the seat.There are two.One works fine and one is stuck.I can't get it to move at all.What can I do?
Allan In NE
04-13-2007 06:41:55
I'll bite. What "Service Valve"?
Are you talking about the air conditioning R-12 service port?
Allan
the tractor vet
04-13-2007 07:48:28
 Re: Service valve in reply to Allan In NE, 04-13-2007 06:41:55
Thats a new one on me , sorta brings back memories of the days in the car dealership when a woman brought a car in and tryed to explain something was wrong.
Allan In NE
04-13-2007 07:51:35
 Re: Service valve in reply to the tractor vet, 04-13-2007 07:48:28
Sounds like he is talking about the remotes. You ever hear of one "sticking"?
I've never ran into that problem before.
Allan
JTinNJ
04-13-2007 08:14:35
 Re: Service valve in reply to Allan In NE, 04-13-2007 07:51:35
Ya,it's the remotes. Sorry for being such a woman.
the tractor vet
04-13-2007 08:51:43
 Re: Service valve in reply to JTinNJ, 04-13-2007 08:14:35
If it is a remote that is stuck try this on the pack you will see a small round plug ( if it has not fallen out ) it will pop out as it is just a push in cap use a small screwdriver this will give you access to the unlatchen screw using a flatblade screwdriver back the screw off a littel bit by turning counter clock wise and see it this will let it unlatch also remove the cover on the ft. below the seat and check to make sure that nothing got behind the linkage . Now ya may have to use a hammer and long drift punch to tap it back and then remove the valve and disassembal to see what has happned . Best to have a book tosee what your dealing with here if you have never been in one before.
JTinNJ
04-13-2007 09:24:47
 Re: Service valve in reply to the tractor vet, 04-13-2007 08:51:43
Now that we have the fact that it is the remote that is stuck cleared up. I did see on the back a small cap.One was there,and,one was missing.And,I did see a screw head.I was wondering if that would release the valve.Should I keep trac of the number of turns,And should I turn it back the same number of turn when it release's? I'm working all weekend.I will give this a try on Monday.I'll try to find a book. I could'nt get the name streight,so you know I've never been inside of this before.Look out..
the tractor vet
04-13-2007 10:02:18
 Re: Service valve in reply to JTinNJ, 04-13-2007 09:24:47
Well yea keep track of the turns i would start with backing it off a 1/4 turn to start . Now since ya have all weekend try and get and I T manual for your tractor from a local farm supply store or a dealer as they all can order them , this will help ya . Just do not force it . Since i can not just run down there and fix it for ya.
JTinNJ
04-13-2007 11:28:13
 Re: Service valve in reply to the tractor vet, 04-13-2007 10:02:18
I'm working at my real job all weekend.12 hours Fri,Sat,Sunday.I'll be off on Mondayand Tuesday. Ya,I'm at work now.
Thanks for the advise.I'll take my time.I have a better understanding now then before.
Allan In NE
04-13-2007 08:20:48
No need to be sorry.
You own a 966, one of the finest tractors to ever turn a wheel. :>)
Allan
the tractor vet
04-13-2007 07:54:58
Yea , i had one that the one unlatchen ball broke and locked it up BIG TIME. It was a fight to get it out.
