Farmall A HAND CRANK KICK BACK
Mark J
04-13-2007 06:40:40
When I hand crank my 47 A it somtimes kicks back pretty hard. Is this due to timing? When I start it with a battery it starts right up and doesn't miss a lick? Any ideas?
Thank you,
MJF
Farmallgray
04-14-2007 11:06:17
 Re: Farmall A HAND CRANK KICK BACK in reply to Mark J , 04-13-2007 06:40:40
I have a BN that kicks back every once in a while. It is NOT spark related though. The mag is timed correctly, and the impulse is tripping properly. I haven"t got it completely figured out yet, but it seems like it is hitting compression on one cylinder and rocking back. It doesn"t even happen when the mag is firing. It doesn"t kick very hard-it just kind of slaps the crank into your hand.
Roger Mills
04-14-2007 08:12:11
Srivice manual says the impulse trips at TDC and normal timing when running is static at 35 degrees before TDC. A comment: if the impulse coupler does not engage it will make a weak spark when hand cranking but usually not enough to "fire". It can try and that will cause it to kick back--or cause the starter to crank slower than normal with a hesitation when it tries to fire.
RNicholas
04-13-2007 19:03:43
Growing up it was a rite of passage to be able to hand crank the A, Super A or 100. Grandaddy taught us to first pull up on the crank (no thumb--fingers only). Once we mastered that technique he showed us how to crank with a down-stroke. The trick was to move the crank out of the pulley as we finished the down-stroke movement. Since the thumb was of no use since it wasn't wrapped around the crank it took some practice. But what a great feeling for a young teen when she fired up. We felt equal to the master himself. God, how I loved that old man.
CSR
04-13-2007 08:31:48
I just fired up my rebuild a couple nights ago and have some questions on how it starts. Its a C113 with an H4 Mag. If I spin it with the starter with the mag off it spins reasonably but when I unground the mag it stops the rotation goes into a spin/no spin/reverse spin a little/spin mode...after a couple of these it lights right off. I suspected advanced timing so with the engine off, I brought it to TDC, compression stroke, #1 cyl. I then loosened the mag and rotated the bottom of the mag towards the block and temporarily secured the bolts. I then did two revolutions of the engine and stopped at TDC (prior to assembling the head, I used a dial indicator to get #1 at TDC then marked the crank pulley and timing cover so I have a good point of reference). I then was planning to rotate the Mag away from the block till the impulse tripped and secure it there. I find the impulse trips exactly when I get to TDC so I didn't have to move it away from the block. Is it typical for a engine to have trouble deciding which way to turn ? If I retard it will it only fire after TDC when starting? Every auto on the road fires before TDC and they don't have trouble deciding on a direction to rotate.
thanks for the input.
Andy Martin
04-13-2007 13:03:14
 Re: Farmall A HAND CRANK KICK BACK in reply to CSR, 04-13-2007 08:31:48
Rotate the mag away from the engine. Then slowly crank to TDC. Rotate the mag toward the engine until it trips. Then you are set at TDC.
Unless the impulse is sticking it will not kick. As other have said, only pull up on the crank with your fingers only and a kick will not hurt you bad.
If the tractor does not run well bu truns better with the mag set earlier the mag needs to be repaired.
Red Dave
04-13-2007 08:47:17
Are you sure the magneto impulse is working?
I don't have the book here in front of me, but If memory serves, it should fire about 35 degrees AFTER TDC at hand cranking speed and change to fire at TDC when the magneto achieves something like 150 RPM. That is what he magneto impulse does for you.
Now that is from memory, gene bender can give you the exact specifications on it.
John T
04-13-2007 09:32:50
 Re: Farmall A HAND CRANK KICK BACK in reply to Red Dave, 04-13-2007 08:47:17
Dave, isnt that supposed to be more like TDC at hand crank RPM but then advanced to something like 25 to 35 BEFORE TDC when running on Mag equipped tractors???? I think if she fired that late AFTER TDC she would be awfully hard to hand start (sure wont ever kick back though) On most mags the centrifugal force/action is what disengages the spring wind n trip impulse mechanism so the run time advance timing then kicks in, maybe in the 150 to 250 or so PRM range.
PS Im of the opinion that 35 BTDC is too much advance and I prefer more like 25 at typical antique tractor engine RPM's on gasoline. I think the 35 degree advance was more like for lower grade slower burning fuels/distillates as opposed to gasoline where I believe 25 degrees of advamce is plenty
Any agreement or disagreement?????
Again Im NOT an IHC Mag man but have experience with plenty others, good topic GREAT discussion..... ...
John T
A. Bohemian
04-13-2007 10:40:24
 Re: Farmall A HAND CRANK KICK BACK in reply to John T, 04-13-2007 09:32:50
On the overwhelming majority of engines, regardless of whether it is a mag or Kettering, whether manual or centrifugal advance, the spark will be retarded well past top dead center in order to assure relatively safe hand cranking, as described below.
A tractor or other vehicle which is hand cranked with the timing closer to top dead center does become easier to start.
It also becomes more deadly. If the timing ever fires before TDC while hand cranking, you will almost always get a kickback.
The chart in the IH-8 manual clearly shows the H4 magneto "with serial numbers 1353301 and up" is supposed to have a lag angle of 35 degrees. Others have a lag angle of 7 deg.
I don"t know squat about IH mags; but I do notice a similarity between what the manual calls "lag angle" and Red Dave"s description of what the impulse does.
In other words, when you set the timing STATICALLY, the impulse DOES trip at TDC. But at hand cranking speed it automatically retards the timing to 35 degrees after top center, pushing up to where it needs to be (before top center) at engine speeds.
Right, Dave?
John T
04-13-2007 11:43:09
 Re: Farmall A HAND CRANK KICK BACK in reply to A. Bohemian, 04-13-2007 10:40:24
Wow, Greattttt t n fun discussion guys, buttttt ttt if IH Mags are anything like Wico ????? ???
AT HAND CRANK RPM AND AT ANYYYYY YYYYY RPM LESS THAT 150 TO 250 OR SO (i.e. while starting) the Impulse trips (according to where its adjusted of course) which should be somewhere around dead TDC....
Then (how Wicos perform at least) the timing advances to the 25 to 35 BTDC ONLY AFTER the 150 to 250 RPM range when the impulse becomes disabled i.e. she snaps/impulses (depending on where its adjusted) to fire near TDC at hand crank RPM and CONTINUES TO FIRE THEN UNTIL AFTERRRRR RRR 150 TO 250 RPM when the impulse is disabled PERIOD ..... ..... ..WITH NO 25 TO 35 "RETARD" SOMEWHERE IN BETWEEN.
I just fail to see how or why they would somehow snap at the adjusted point (near TDC) when hand cranking,,,,, ,,,,, ,,,,, ,,,,, ,,,,, but then somehow change to 25 to 35 RETARD,,,,, ,,,,, ,,,,, ,,,,, ,,,,, ,,,,, ,,,, and then over 150 to 250 RPM change again to 25 to 35 BTDC ADVANCE?????
On the Wico Mags the reason n how they advance over 250 RPM is simply cuz centrifugal force causes the engage dogs to suck in whereby the spring wind n trip (impulse) mechanism IS DISABLED That way they fire at the static starting timing (which one adjusts to near TDC) while cranking and up until 250 RPM, buttttt tt above that since the engage dogs dont extend they fire at the advanced run timing which is a function of the drive cup (like if its a 25 or 35 BTDC cup) plus the dynamic rotational mag timing adjustment.
The so called "Lag Angle" is how much the static start (impulse) timings Lagsssss sss the advance run timing and its adjustable. On the Wico Mags (and I would guess IHC are the same) theres ONLY TWO times, the static start (Impulse) timing and the advance run timing over 250 RPM with no other 25 to 25 RETARD at some time after hand cranking but before 150 to 250 RPM ????? ????? ??
HOPE THE IHC MAG EXPERTS CAN CONFIRM OR SHOOT THIS DOWN LOL Do they have ONLY a static start time (impulse) and an advance run time over 150 to 250 RPM
orrrrr rrrrr
Do they fire at TDC,,,, then Retard to 25 to 35 AFTER TDC,,,,, ,,,then go back to 25 to 35 BTDC Advance
My bets on the former i.e. ONLY a start impulse static timing and an advance run timing over 150 to 250 RPM PERIOD?????
God Bless yall, take care SPRING IS CLOSE BYYYYY YYYYY
Will an IHC Mag expert PLEASE answer all this ??? makin me curious
John T in Indiana
A. Bohemian
04-13-2007 12:11:13
 I Will Defer... in reply to John T, 04-13-2007 11:43:09
...to your opinion, John T. You are an engineer and I am only a technician.
Quote: "The so called "Lag Angle" is how much the static start (impulse) timings Lagsssss sss the advance run timing and its adjustable."
Got it, and thanks. So if the advance run timing is, say some number of degrees before top center, the start timing would be 35 degrees behind that?
I"m fairly sure of one thing; when hand cranking an engine, the timing MUST be such that the spark fires after top center. Otherwise, you"d have a very dangerous situation.
As I"ve noted, on engines with manual spark advance, the engine does indeed sputter and often die before you can advance the spark.
John T
04-13-2007 13:29:14
 Re: I Will Defer... in reply to A. Bohemian, 04-13-2007 12:11:13
Wooooo Hooooo Looks like we may finger this thing out ourselves without any "experts" even lol Trouble is I dont know beans about them IHC Mags and am anxious to learn from yall here.
I think all that "Lag Angle" stuff is merely a way of lookin at it. I consider (and Wico does) its the angle the run time advance "lags" behind the impulse start time. i.e. if the lag angle is 35 degrees and she advance run times at 35 BTDC she would start/impulse right at TDC. I got to thinkin I agree with your notion in a way, its just that when you say 35 RETARD I think you meant she retards 35 BEHIND the run time advance NOT that she ever fires 35 AFTER TDC sooooo ooo lateeeee eeee, which is far to slow to ever start fer sure, although she could run poorly I reckon??
By The way me bein a retired engineer dont make me know more then anyone here whatsoever, it just means Im knee deep in theory, but as far as IHC mags I have like nooooo ooooo ooo experience and hope to learn n help others when I can. I give elctrical seminars at some of the national John Deere Shows and have written for some JD magazines but havent owned IHC for yearsssss sssss ss.
THanks for the great discussion I enjoy your informative posts and love this sparky chat as Im sure you see.
Take care now AB
John T
Owen Aaland
04-13-2007 15:05:24
 Re: I Will Defer... in reply to John T, 04-13-2007 13:29:14
There is no advance built into the H4 mag, only retard.
The impulse coupler causes retarding when the speed slows enough the engage the pawl. The degrees retarded is the angle traveled before the pawl releases. I do not remember amount of retard built in, but the mag runs with only two timing positions. Retarded at TDC and normal running position.
This is why IH wanted the mags replaced when using fire creater pistons. The distributors are variable with engine speed and ran more advance than the magneto normal timing at high idle.
John T
04-13-2007 15:45:30
 Re: I Will Defer... in reply to Owen Aaland, 04-13-2007 15:05:24
Thanks Owen, Thats what I expected to hear, same as the JD Wico n sooooo o many (maybe all) others. The Wico is also "retarted" at low hand crank RPM cuz the engage dogs extend out to wind the impulse spring buttttt t at 250 RPM centrifugal force holds them in so the free running (impulse disabled) drive cup position determines when the points break open to fire which becomes the run timing.
John T
Owen Aaland
04-14-2007 05:46:05
 Re: I Will Defer... in reply to John T, 04-13-2007 15:45:30
Yes, but you said it much better than I did.
A. Bohemian
04-13-2007 07:38:06
 Looks Like a Concensus in reply to Mark J , 04-13-2007 06:40:40
The primary cause of severe kick-back, where the engine fires and even backwards and catches the pawls of the crank, tuning it into a death machine out of a Kung-Fu flick, is that the spark is occuring before TDC.
This is a big reason why it is relatively safe to crank a tractor with a conventional Kettering system that is also equipped with centrifugal advance, such as other Farmalls and many John Deers. If functioning properly, the centrifugal advance usually assures the spark is retarded past TDC for starting.
On Model T, where the spark advance was manually set by a lever on the steering column, many a child and other non-driver was taught to get "get that spark lever down!" on command once the engine fired.
That way the person cranking could start with the spark well retarded, which often made the engine splutter and miss and only run for few critcal seconds but which assured SAFE cranking.
(And, there were even a few ancient cars, like some Packards, where once the engine is warmed up one has only to flick the spark control through its range to start the engine WITHOUT cranking!)
So, check the mag for correct operation. In the meantime, be VERY careful cranking this tractor!
Henry Leland, head man at Cadillac, commissioned the first modern self-starting system from Charles Kettering, because a close friend of Leland's was killed cranking a Cadillac.
Never wrap your thumb around a crank. (Or a steering wheel when going cross-rows!)
Always pull UP on the crank, standing slightly off to the side.
And, as others have said, ALWAYS have the spark retarded below top dead center!
Wardner
04-13-2007 10:33:12
 Re: Looks Like a Concensus in reply to A. Bohemian, 04-13-2007 07:38:06
Yep, I had a 1923 Graham Brothers truck (Dodge engine) that would start by moving the retard lever. It would happen in one out of four or five hot starts.
Red Dave
04-13-2007 07:15:12
A Farmall with the impulse on the magneto should NEVER kick back if it is working properly and timed properly.
Bob's advice below is right on the money.
Check the timing and make sure the impulse is working right.
NDS
04-13-2007 07:26:44
 Re: Farmall A HAND CRANK KICK BACK in reply to Red Dave, 04-13-2007 07:15:12
Had someone tell me that about 3 years ago and next time I saw him he had broken arm. He was kicked by M Moline though not Farmall.
Red Dave
04-13-2007 08:49:51
 Re: Farmall A HAND CRANK KICK BACK in reply to NDS, 04-13-2007 07:26:44
You're on your own when it comes to those off-brands ;)
John T
04-13-2007 07:09:27
Mark, I agree with Hal n Bob's good advice, only one thing to add. While its true if the mag impulses/fires/snaps BEFORE TDC that can cause kickback as the gas explosion drives the piston back down (in wrong crank direction) but its been my experience hand crankers start best just at that critical point where shes start/impulse timed as close as possible or even maybe a degree or so BEFORE TDC JUST TO WHERE SHE DONT KICK BACK. Of course, such a close critical timing location is hard to achieve and replicate consistently due to sticky impulse n wear etc. I generally set em at dead TDC and try starting several times and then with a lil hammer/adjuster etc gently adjust/tap them advanced just 1/2 hair at a time so she still starts good but, of course, if she ever kicks back then I retard them. NOTE Im NOT an IHC Mag man, however Ive found this to generally hold true for abouT any hand start tractor, i.e. set em as close to dead TDC or a hair before BUT NOT TOO ADVANCED SHE KICKS BACK.
I'm curious if others find this true???
John T in Indiana
NDS
04-13-2007 07:08:25
They will all kick back sooner or later have seen several broken arms and wrists from handcranking tractors. If you are going to hand crank it NEVER spin crank place crank at bottom and pull up keeping thumb off top of crank. No matter how well tractor is tuned a little moisture can cause cross firing.
Bob
04-13-2007 06:56:29
Be careful, and always follow the recommended procedure for cranking "just in case"!
Apparently, you have "mag" ignition.
The timing should be set no earlier than TDC, or you risk a "kicback"
With the "kill switch" "OFF", slowly bring the engine up on #1 TDC. The spark occurs when you hear the mag's impulse "trip".
The timing marks can be viewed by removing the little cover under the flywheel, and looking UP at them.
See where the timing is set... since it doesn't always "kick", the problem COULD be related to a sticky, gummy "impulse" in the mag, if the timing IS correct.
El Toro
04-13-2007 06:53:08
Your timing may be advanced too far. Hal
