Farmall H - x2 transmission?
Easy1
04-14-2007 22:48:40
I thought that X1 meant a rockford clutch, what is a x2? This from a local want ad.
City-boy McCoy
04-15-2007 03:44:50
 Re: Farmall H - x2 transmission? in reply to Easy1, 04-14-2007 22:48:40
"X-1" stands for gasoline only engine. "J" stands for Rockford clutch. I think the person who wrote the ad is trying to abbreviate the fact the tractor has a high and low range transmission, i.e., an aftermarket conversion in the transmission. We usually call them 9-speeds here on the forum. mike
farmerweber in PA
04-14-2007 23:23:05
According to Guy Fay"s Farmall Letter Series Tractors x2 means modified.Other than the x standing for the farmalls(row crops),don"t know what the modification would be.Might be pretty interesting to find out.
georgeky
04-15-2007 07:26:24
 Re: Farmall H - x2 transmission? in reply to farmerweber in PA, 04-14-2007 23:23:05
I have wondered myself what was modified. Maybe someone will chime in with the answer.
City-Boy McCoy
04-15-2007 08:45:32
 Re: Farmall H - x2 transmission? in reply to georgeky, 04-15-2007 07:26:24
"x2 transmission" is a commonly used term in tractor ads, today, to relate that the subject tractor has a high and low range transmission. In the case of a farmall H, it would mean the tractor was equipped with something like an M&W 9-speed. I believe that is what this ad means. mike
City-Boy McCoy
04-15-2007 08:51:10
 Re: Farmall H - x2 transmission? in reply to City-Boy McCoy, 04-15-2007 08:45:32
Allow me to point out, Easy1 states he is quoting from the ad, not the serial number plate. mike
georgeky
04-15-2007 09:45:48
 Re: Farmall H - x2 transmission? in reply to City-Boy McCoy, 04-15-2007 08:51:10
Mike, I am still curious to the X2 suffix, and the meaning of modified. All my book says is modified. What is modified?
John M
04-15-2007 11:09:12
 Re: Farmall H - x2 transmission? in reply to georgeky, 04-15-2007 09:45:48
I think, if I recall correctly, it was something done after the tractor was built, or it was something either left off of the tractor or added to the tractor for a particualr reason such as the ones being built for say Trojan.
georgeky
04-15-2007 13:02:05
 Re: Farmall H - x2 transmission? in reply to John M, 04-15-2007 11:09:12
John M. I bet you are on the right path. It didn't dawn on me about the road graders and things. I saw a picture a day or two ago of an H with rollers on it. I guess it was set up as a pavement roller. I have seen graders, but that was the first roller I had seen. I do know that cotton pickers had X20. I could have bought a M grader a few years back for 1000 bucks, but didn't. The wife would have had a fit anyhow.
City-Boy McCoy
04-15-2007 14:21:46
 Re: Farmall H - x2 transmission? in reply to georgeky, 04-15-2007 13:02:05
George, now I see what you mean. Yes, the graders would be an example. Also, perhaps a tractor with a special low clearance exhaust system or something similar? mike
georgeky
04-15-2007 15:18:24
 Re: Farmall H - x2 transmission? in reply to City-Boy McCoy, 04-15-2007 14:21:46
I don't know why that never dawned on me. Common sense should tell a feller it was along them lines.
